Générer un certificat SSL auto-généré (paire certificat/clé)
#!/bin/sh
# Generates a self-signed certificate.
# Edit openssl.cnf before running this.
umask 077
OPENSSL=${OPENSSL-openssl}
# Define SSL directory
SSLDIR=${SSLDIR-/opt}
# Define SSL config file
OPENSSLCONFIG=${OPENSSLCONFIG-/opt/openssl.cnf}
# Define crt/key directories
CERTDIR=$SSLDIR/certs
KEYDIR=$SSLDIR/private
# Define crt/key file
CERTFILE=$CERTDIR/mynewssl.pem
KEYFILE=$KEYDIR/mynewssl.key
# Define validity duration for the cert
DAYS=365
# Check that directories exist or create themt
if [ ! -d $CERTDIR ]; then
  mkdir -p $CERTDIR
fi
if [ ! -d $KEYDIR ]; then
  mkdir -p $KEYDIR
fi
# Check that the files do not exist or move them
if [ -f $CERTFILE ]; then
  mv $CERTFILE $CERTFILE.old
fi
if [ -f $KEYFILE ]; then
  mv $KEYFILE $KEYFILE.old
fi
# Generate crt/key files
$OPENSSL req -new -x509 -nodes -config $OPENSSLCONFIG -out $CERTFILE -keyout $KEYFILE -days $DAYS || exit 2
chmod 0600 $KEYFILE
echo
$OPENSSL x509 -subject -fingerprint -noout -in $CERTFILE || exit 2
