Crash au demarage avec Vista 64 ultimate
oliflo
bonsoir,
j'ai tout essayé...enfin presque...
reinstallation dans un repertoire autre, par dessus....etc.. lancement en mode compatibilité...
j'ai le meme message 'maxthon browser a cessé de fonctionner' à chaque demarrage
ma config
CM : evga n680i
CG :8 800
MEM: 2 go
OS : win wista 64 fr à jour
je vous joint le log que j'ai reussi a avoir....
merci de votre aide/astuce
[General]
UID=216691
[CrashInfo]
Code=c0000005
Stack=%0D%0A%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3DFault+Info%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%0D%0AException+code%3A+C0000005+ACCESS_VIOLATION%0D%0AFault+address%3A++7754D058+01%3A0002D058+C%3A%5CWindows%5CSysWOW64%5Cntdll.dll%0D%0A%0D%0ACall+stack%3A%0D%0AAddress+++Frame+++++Function++++++++++++SourceFile%0D%0A7754D058++0651D568++0001%3A0002D058+C%3A%5CWindows%5CSysWOW64%5Cntdll.dll%0D%0A7754CF78++0651D590++0001%3A0002CF78+C%3A%5CWindows%5CSysWOW64%5Cntdll.dll%0D%0A02BD4A4E++0651D598++0001%3A00003A4E+C%3A%5CWindows%5Csystem32%5Cnvappfilter.dll%0D%0A02BD6425++0651D5B0++0001%3A00005425+C%3A%5CWindows%5Csystem32%5Cnvappfilter.dll%0D%0A76653891++0651D5D0++0001%3A00002891+C%3A%5CWindows%5Csyswow64%5CWS2_32.dll%0D%0A001B4913++0651D5DC++0001%3A00003913+C%3A%5CUsers%5Coliflo%5CAppData%5CRoaming%5CMaxthon222%5CMxSk.dll%0D%0A001B4958++0651D5E8++0001%3A00003958+C%3A%5CUsers%5Coliflo%5CAppData%5CRoaming%5CMaxthon222%5CMxSk.dll%0D%0A001B42D1++0651D61C++0001%3A000032D1+C%3A%5CUsers%5Coliflo%5CAppData%5CRoaming%5CMaxthon222%5CMxSk.dll%0D%0A763F1220++7755A69D++0001%3A00001220+C%3A%5CWindows%5Csyswow64%5Ckernel32.dll%0D%0A
System=%3C--------------------+Maxthon+Information+------------------------%3E%0D%0A%0D%0AVersion%3D2.0.4.5799++++++++Unicode%0D%0A--------+Maxthon+Plugins+--------%0D%0A%0D%0A%3C--------------------+System+Information+--------------------%3E%0D%0A%0D%0AOS%3DGreater+than+Win2K%0D%0AIE+Version%3D7.0.6000.16546%0D%0A--------+Processes+--------%0D%0A%5BSystem+Process%5D%0D%0ASystem%0D%0Asmss.exe%0D%0Acsrss.exe%0D%0Awininit.exe%0D%0Acsrss.exe%0D%0Aservices.exe%0D%0Alsass.exe%0D%0Alsm.exe%0D%0Asvchost.exe%0D%0Asvchost.exe%0D%0Asvchost.exe%0D%0Awinlogon.exe%0D%0Asvchost.exe%0D%0Asvchost.exe%0D%0Asvchost.exe%0D%0Aaudiodg.exe%0D%0ASLsvc.exe%0D%0Asvchost.exe%0D%0Asvchost.exe%0D%0Aspoolsv.exe%0D%0Asvchost.exe%0D%0Ataskeng.exe%0D%0Amdm.exe%0D%0Asvchost.exe%0D%0Asvchost.exe%0D%0Asvchost.exe%0D%0ASearchIndexer.exe%0D%0AnSvcAppFlt.exe%0D%0Adwm.exe%0D%0AnSvcIp.exe%0D%0Aexplorer.exe%0D%0AWmiPrvSE.exe%0D%0AWUDFHost.exe%0D%0Ataskeng.exe%0D%0AMSASCui.exe%0D%0Anvraidservice.exe%0D%0Arundll32.exe%0D%0Arundll32.exe%0D%0Asidebar.exe%0D%0Amsnmsgr.exe%0D%0Adaemon.exe%0D%0Aunsecapp.exe%0D%0ACTHELPER.EXE%0D%0ACTXFIHLP.EXE%0D%0ACTXFISPI.EXE%0D%0Asidebar.exe%0D%0Aeverest.exe%0D%0Ausnsvc.exe%0D%0Asplwow64.exe%0D%0Awlmail.exe%0D%0Acsrss.exe%0D%0Awinlogon.exe%0D%0Ataskeng.exe%0D%0Adwm.exe%0D%0Aexplorer.exe%0D%0AMSASCui.exe%0D%0Anvraidservice.exe%0D%0Arundll32.exe%0D%0Asidebar.exe%0D%0Amsnmsgr.exe%0D%0ACTHELPER.EXE%0D%0ACTXFIHLP.EXE%0D%0ACTXFISPI.EXE%0D%0Arundll32.exe%0D%0Aunsecapp.exe%0D%0Aiexplore.exe%0D%0ASearchProtocolHost.exe%0D%0ASearchFilterHost.exe%0D%0AMaxthon.exe%0D%0A
Télécharge cette version ICI et le fichier langue LA, et réinstalle dans un nouveau dossier !
bonjour,
je viens de la faire... cela a fonctionné 1'...puis de nouveau la même erreur...
aarrrgggg ! :zen: comment vais je pouvoir faire sans ce brillant browser....
si l'un d'entre vous à une astuce... je suis preneur, sinon je vais attendre la prochaine maj...qui sais...
merci
bonjour,
merci
Bonjour oliflo,
J'ai cherché sur ce forum, sans rien trouver, mais il me semble avoir lu, ici, ou peut-être sur un autre forum, qu'il y avait, pour l’instant, une incompatibilité entre Vista 64 bits et Maxthon 2.0x, incompatibilité qui, si ma mémoire ne me joue pas des tours, n'existe pas avec la version 1.x.
Essaye la dernière version 1.6.3 build 80 et confirme où infirme mon impression.
Bonjour oliflo,
J'ai cherché sur ce forum, sans rien trouver, mais il me semble avoir lu, ici, ou peut-être sur un autre forum, qu'il y avait, pour l'instant, une incompatibilité entre Vista 64 bits et Maxthon 2.0x, incompatibilité qui, si ma mémoire ne me joue pas des tours, n'existe pas avec la version 1.x.
Bonsoir Ray1,
merci pour l'info... j'ai tardé à la faire ... mais bonne nouvelle cela fonctionne depuis pres de 10'...
donc pour le moemnt je te confirme que cette version fonctionne à merveille sur vista 64...
pour ceux qui ne comprennent pas pourquoi il y a des 'gens bizzare' qui ont installé vista en 64 bits... hé ben c'est juste pour un probleme de Ram (un systeme 32 bits ne gere que 4 Go de ram mawimun...au global du pc...donc ram GPU inclus => n'achetez pas un pc avec 4 go de ram et une carte video de 768 Mo...car au final vous aurez 768Mo de ram de votre systeme qui ne sera jamais adressé...en clair qui dormiras sans pouvoir être utilisé...j'en ai fait l'amère experience...)
Bonsoir Ray1,
Super ! Mais ne vendons pas trop vite la peau de l'ours (mais non dixours, ce n'est qu'une image Oui4.gif ), cette solution te permettra d'attendre que la version 2.0x soit compatible avec Vista 64 bits.
Tiens nous tout de même informés de la stabilité de la version 1.6x sous Vista 64 bits, merci par avance. big_pouceenhaut.gif
En effet, il me semble que Maxthon v2 n'est pas compatible avec Vista 64 bits contrairement à Maxthon v1 (1.6.3 build 80 pour la dernière version de la v1, indiquée par Ray)
Par contre tu m'étonnes un peu oliflo sur l'histoire de la RAM sous un système 32 et 64 bits :sneaky: Je ne remets pas du tout ta parole en doute, mais je suis sceptique... Je sais que le système 64 bits accepte plus de RAM que le 32, mais pour le reste... ricouz peut-être pourra-t-il nous éclairer ?
Je confirme, un processeur 32 bits ne peux pas adresser plus de 4 go alors qu'un processeur 64bits en théorie peut adresser 16 To (si ne ne me suis pas trompé cela doit faire 18446744073709551616 octets)
Je ne vais pas entrer dans le détails des calculs, mais pour simplifier, imagine une adresse sur 32 bits c'est comme si tu avais 32 cases ou tu peux représenter une adresse avec des 1 et des 0, avec un processeur 64 bits ben tu as 64 cases avec des 1 et des 0 pour représenter une adresse donc énormément plus de possibilités.
Bon puisque vous insistez voilà les calculs
32 bits c'est 2 à la puissance 32 donc 4294967296 octets soit 4 Go
je ne vous fais pas le dessin pour 64 bits :sneaky:
2° avantage du 64 bits, si on a une instruction processeur sur 64 bits et que l'on utilise seulement 32 bits il faudra 2 cycles d'horloge pour la transmettre au processeur, avec un processeur 64 bits on aura besoin que d'un seul cycle.
  • 2 semaines après...
  • 1 mois après...
Hello tlm
Un peu idem pour moi, pourtant je n'ai qu'un Vista 32 bits !!!
Comme j'ai laissé tomber un peu Max, suite à mes différents petits probs que j'avais énoncé sur d'autres topics.
Je voulais quand même retester avec la toute dernière version de Max, mais je rencontre toujours les même probs.
J'ai l'impression que ça n'évolu par pour un sous sous Vista !!!
Alors qu'est ce que ça doit être sous 64 bits ???
Hello Ray
Eh oui, moi, même avec le SP1 ça merde !!!
Et ce n'est pas Vista qui merde mais bien Maxthon.
Ces derniers temps, je tourne avec le Renard, et tout fonctionne comme il faut,
Sauf que je n'arrive pas à m'y faire, (petite allergie !!! mellow.png )
Je ne retrouve pas mes fonctions que j'utilisais sous Max.
Hello Ray
Pourrais-tu avec oliflo, nous faire un descriptif détaillé des circonstances des plantages que vous constatez l'un et l'autre, comme j'ai mon fils ici je vais lui faire traduire votre problème pour le faire remonter aux développeurs.
Merci par avance.
Hello
Bin le mien, il est simple, enfin celui qui me gêne le plus:
C'est quand Max est ouvert, et que je clique sur un lien dans Outlook 2007, le lien s'ouvre, (l'onglet clignote dans la barre des tâche), mais Maxthon reste en arrière plan, c'est à dire qu'il n'apparait pas, c'est Outlook qui reste à l'écran.
Quand Max n'est pas encore ouvert, alors là il s'ouvre et apparait suite à un clic sur un lien dans Outlook.
Ça ne me le fait pas, ni sous IE, ni sous Firefox.
Hello
mess10.gif Meny,
Je le fais traduire par mon fils et je le poste demain sur le forum anglais adéquat. Clin03.gif
Ok,
Merci Raymond.
Je fais remonter le descriptif de ton défaut sur le forum anglais, ce qui nous donne (après traduction par mon fils) :
Problem with Vista SP1 and IE7, between Maxthon 2.0.7.1030 and Outlook 2007
When Maxthon is already open, and when i click under Outlook 2007, the link opens (blinking in the taskbar) but Maxthon still stay on background, leaving Outlook on foreground. If Maxthon is not open, then it open on foreground when i click on a link under Outlook. It works straigthfully under IE and FireFox.
Did this flaw already reported to developers?
Otherwise, did you know a solution for this?
Le lien sur le forum anglais
Je te tiendrais informé des réponses obtenues, ici.
J'ai besoin de l'aide d'un linguiste distingué in english, pour m'aider à traduire les quatres pistes proposée par JarC sur le forum anglais, mon anglais est trop succint.
merci.gif par avance à LDFA ou Ricouz par exemple
C'est à priori un bug de Maxthon v2.0.
abc@home propose de décocher Activer le support des processus multiples pour les onglets dans le Centre de configuration de Maxthon -> Avancé.
Bloodchen nous dit qu'ils y sont dessus.
C'est un bug qui existe aussi sous Windows XP, mais c'est pas ça qui me fera utiliser Firefox !!! :shy:
