Ldfa Posté(e) le 31 décembre 2019 Posté(e) le 31 décembre 2019 #!/bin/sh # # Simple Firewall configuration. # # Author: Nicolargo # # chkconfig: 2345 9 91 # description: Activates/Deactivates the firewall at boot time # ### BEGIN INIT INFO # Provides: firewall.sh # Required-Start: $syslog $network # Required-Stop: $syslog $network # Default-Start: 2 3 4 5 # Default-Stop: 0 1 6 # Short-Description: Start firewall daemon at boot time # Description: Custom Firewall scrip. ### END INIT INFO PATH=/bin:/sbin:/usr/bin:/usr/sbin # Services that the system will offer to the network TCP_SERVICES="22" # SSH only UDP_SERVICES="" # Services the system will use from the network REMOTE_TCP_SERVICES="80 443" # web browsing REMOTE_UDP_SERVICES="53" # DNS # Network that will be used for remote mgmt # (if undefined, no rules will be setup) # NETWORK_MGMT=192.168.0.0/24 # Port used for the SSH service, define this is you have setup a # management network but remove it from TCP_SERVICES SSH_PORT="22" if ! [ -x /sbin/iptables ]; then exit 0 fi ########################## # Start the Firewall rules ########################## fw_start () { # Input traffic: /sbin/iptables -A INPUT -m state --state ESTABLISHED,RELATED -j ACCEPT # Services if [ -n "$TCP_SERVICES" ] ; then for PORT in $TCP_SERVICES; do /sbin/iptables -A INPUT -p tcp --dport ${PORT} -j ACCEPT done fi if [ -n "$UDP_SERVICES" ] ; then for PORT in $UDP_SERVICES; do /sbin/iptables -A INPUT -p udp --dport ${PORT} -j ACCEPT done fi # Remote management if [ -n "$NETWORK_MGMT" ] ; then /sbin/iptables -A INPUT -p tcp --src ${NETWORK_MGMT} --dport ${SSH_PORT} -j ACCEPT else /sbin/iptables -A INPUT -p tcp --dport ${SSH_PORT} -j ACCEPT fi # Remote testing /sbin/iptables -A INPUT -p icmp -j ACCEPT /sbin/iptables -A INPUT -i lo -j ACCEPT /sbin/iptables -P INPUT DROP /sbin/iptables -A INPUT -j LOG # Output: /sbin/iptables -A OUTPUT -j ACCEPT -o lo /sbin/iptables -A OUTPUT -m state --state ESTABLISHED,RELATED -j ACCEPT # ICMP is permitted: /sbin/iptables -A OUTPUT -p icmp -j ACCEPT # So are security package updates: # Note: You can hardcode the IP address here to prevent DNS spoofing # and to setup the rules even if DNS does not work but then you # will not "see" IP changes for this service: /sbin/iptables -A OUTPUT -p tcp -d security.debian.org --dport 80 -j ACCEPT # As well as the services we have defined: if [ -n "$REMOTE_TCP_SERVICES" ] ; then for PORT in $REMOTE_TCP_SERVICES; do /sbin/iptables -A OUTPUT -p tcp --dport ${PORT} -j ACCEPT done fi if [ -n "$REMOTE_UDP_SERVICES" ] ; then for PORT in $REMOTE_UDP_SERVICES; do /sbin/iptables -A OUTPUT -p udp --dport ${PORT} -j ACCEPT done fi # All other connections are registered in syslog /sbin/iptables -A OUTPUT -j LOG /sbin/iptables -A OUTPUT -j REJECT /sbin/iptables -P OUTPUT DROP # Other network protections # (some will only work with some kernel versions) echo 1 > /proc/sys/net/ipv4/tcp_syncookies echo 0 > /proc/sys/net/ipv4/ip_forward echo 1 > /proc/sys/net/ipv4/icmp_echo_ignore_broadcasts echo 1 > /proc/sys/net/ipv4/conf/all/log_martians echo 1 > /proc/sys/net/ipv4/icmp_ignore_bogus_error_responses echo 1 > /proc/sys/net/ipv4/conf/all/rp_filter echo 0 > /proc/sys/net/ipv4/conf/all/send_redirects echo 0 > /proc/sys/net/ipv4/conf/all/accept_source_route } ########################## # Stop the Firewall rules ########################## fw_stop () { /sbin/iptables -F /sbin/iptables -t nat -F /sbin/iptables -t mangle -F /sbin/iptables -P INPUT DROP /sbin/iptables -P FORWARD DROP /sbin/iptables -P OUTPUT ACCEPT } ########################## # Clear the Firewall rules ########################## fw_clear () { /sbin/iptables -F /sbin/iptables -t nat -F /sbin/iptables -t mangle -F /sbin/iptables -P INPUT ACCEPT /sbin/iptables -P FORWARD ACCEPT /sbin/iptables -P OUTPUT ACCEPT } ########################## # Test the Firewall rules ########################## fw_save () { /sbin/iptables-save > /etc/iptables.backup } fw_restore () { if [ -e /etc/iptables.backup ]; then /sbin/iptables-restore < /etc/iptables.backup fi } fw_test () { fw_save sleep 30 && echo "Restore previous Firewall rules..." && fw_restore & fw_stop fw_start } case "$1" in start|restart) echo -n "Starting firewall.." fw_stop fw_start echo "done." ;; stop) echo -n "Stopping firewall.." fw_stop echo "done." ;; clear) echo -n "Clearing firewall rules.." fw_clear echo "done." ;; test) echo -n "Test Firewall rules..." fw_test echo -n "Previous configuration will be restore in 30 seconds" ;; *) echo "Usage: $0 {start|stop|restart|clear|test}" echo "Be aware that stop drop all incoming/outgoing traffic !!!" exit 1 ;; esac exit 0 Afficher l’article complet
